node is not consistent
Yan
Post by Yan »
I met some problems about the inconsistent node. Please see the attached example. After I used EM algorithm to learn the parameter, it said sum of probabilities should be 1 (please see fig.1). However, after I changed the value of 2.2185907e-25 to 0.0000000001, this problem was solved (see fig.2). I would like to know why this happens. And 2.2185907e-25 is much smaller than 0.0000000001, why after I changed the value, this problem can be solved?
Many thanks.
Kind regards,
Yan
fig.1
fig.1
fig.2
fig.2
Re: node is not consistent
I can't reproduce the problem. I have typed the numbers in your screenshots and got no warning icon with the 2e-25 value.
Can you send me your xdsl file (use a forum private message if model contains confidential information).
BTW: you can hover the mouse cursor over the warning icon sign and the program will show a tooltip with the additional information about the problem.
We tracked down this problem to GeNIe's algorithm for epsilon selection. If a column in the CPT has a very small non-zero probability (like 2e-25 in your example), it will be used for comparison of the total probabilities in the column with 1.0. The default epsilon is on the order of 1e-6.
This algorithm was implemented before GeNIe supported parameter learning. We'll be switching to constant 1e-6 epsilon for all consistency checks in GeNIe.
Yan
Post by Yan »
shooltz[BayesFusion] wrote: Wed Apr 06, 2022 12:57 pm We tracked down this problem to GeNIe's algorithm for epsilon selection. If a column in the CPT has a very small non-zero probability (like 2e-25 in your example), it will be used for comparison of the total probabilities in the column with 1.0. The default epsilon is on the order of 1e-6.
Thanks Schooltz. Can I understand it as "2e-25" is much smaller than the default smallest value in the algorithm, it will not affect the result of the BN model too much, so we can ignore this issue?
You can ignore the issue. Your model is closer to the perfect sum=1.0 distribution that our default epsilon.
Before we release new version, you can consider using the 'Complement' command in the columns with warnings to get perfect 1.0 total.
