I met some problems about the inconsistent node. Please see the attached example. After I used EM algorithm to learn the parameter, it said sum of probabilities should be 1 (please see fig.1). However, after I changed the value of 2.2185907e-25 to 0.0000000001, this problem was solved (see fig.2). I would like to know why this happens. And 2.2185907e-25 is much smaller than 0.0000000001, why after I changed the value, this problem can be solved?
Many thanks.
Kind regards,
Yan
node is not consistent
- fig.1
- Picture1.png (10.24 KiB) Viewed 15849 times
- fig.2
- Picture2.png (9.99 KiB) Viewed 15849 times
Re: node is not consistent
I can't reproduce the problem. I have typed the numbers in your screenshots and got no warning icon with the 2e-25 value.
Can you send me your xdsl file (use a forum private message if model contains confidential information).
BTW: you can hover the mouse cursor over the warning icon sign and the program will show a tooltip with the additional information about the problem.
We tracked down this problem to GeNIe's algorithm for epsilon selection. If a column in the CPT has a very small non-zero probability (like 2e-25 in your example), it will be used for comparison of the total probabilities in the column with 1.0. The default epsilon is on the order of 1e-6.
This algorithm was implemented before GeNIe supported parameter learning. We'll be switching to constant 1e-6 epsilon for all consistency checks in GeNIe.
Thanks Schooltz. Can I understand it as "2e-25" is much smaller than the default smallest value in the algorithm, it will not affect the result of the BN model too much, so we can ignore this issue?shooltz[BayesFusion] wrote: Wed Apr 06, 2022 12:57 pm We tracked down this problem to GeNIe's algorithm for epsilon selection. If a column in the CPT has a very small non-zero probability (like 2e-25 in your example), it will be used for comparison of the total probabilities in the column with 1.0. The default epsilon is on the order of 1e-6.
You can ignore the issue. Your model is closer to the perfect sum=1.0 distribution that our default epsilon.
Before we release new version, you can consider using the 'Complement' command in the columns with warnings to get perfect 1.0 total.
