I was wondering whether there are any example-networks (not toy examples) available online as part of the documentation?
for instance, is the network described in the sensitivity analysis section available as part of genie's online resources in .xdsl format? (is the dataset used for that network's sensitivity calculation available as well?)
https://support.bayesfusion.com/docs/Ge ... itybn.html
Example network?
Re: Example network?
Have you tried our network repository? You can download all models from the repository directly from inside GeNIe: Just try "Open from BayesBox..." The default BayesBox address is the address of our model repository. All these networks are, I believe, also installed on your disk drive (inside the Program Files\GeNIe directory).
