Sample code (Python preferred) for Dynamic Bayesian Network
rmorales
Post by rmorales »
I have searched for sample code showing how to create a DBN and do some inferences with it (preferably but not necessarily in Python), and I
have found nothing. Do you know of any samples you can share with me?
Regards,
Rafael
Re: Sample code (Python preferred) for Dynamic Bayesian Network
Post by piotr [BayesFusion] »
I'll try to explain PySmile DBN usage based on GeNIe documentation: https://support.bayesfusion.com/docs/Ge ... ngdbn.html
1. Create CPT nodes, ex.
net.add_node("Location")
net.add_node("Rain")
net.add_node("Umbrella")
2. Set node temporal types
net.set_node_temporal_type("Rain", pysmile.NodeTemporalType.PLATE)
net.set_node_temporal_type("Umbrella", pysmile.NodeTemporalType.PLATE)
Default type is CONTEMPORAL, so you don't have to change Location node type.
3. Create arcs
4. Set node definitions
net.set_node_definition("Location", [0.5, 0.5])
net.set_node_definition("Rain", [0.9,0.1,0.2,0.8])
net.set_node_temporal_definition("Rain", [0.7,0.3,0.3,0.7,0.001,0.999,0.01,0.99])
5. Update beliefs and check if everything is ok.
rmorales
Post by rmorales »
Thank you! However, I got this error message:
TypeError: add_node(): incompatible function arguments. The following argument types are supported:
    1. (self: pysmile.Network, node_type: int, node_id: unicode) -> int
    2. (self: pysmile.Network, node_type: int) -> int
    3. (self: pysmile.Network) -> int
I fixed it this way
        handle = net.add_node()
        net.set_node_temporal_type(handle, pysmile.NodeTemporalType.PLATE)
        net.set_node_id(handle,id)
        net.set_node_name(handle, name)
Then I got the following error:
TypeError: set_node_temporal_definition(): incompatible function arguments. The following argument types are supported:
    1. (self: pysmile.Network, node_handle: int, order: int, definition: List[float]) -> None
    2. (self: pysmile.Network, node_id: unicode, order: int, definition: List[float]) -> None
So I guessed order was the number of time steps in the temporal relation, so I set it to 1, and the network definition is working.
I let you know about the inference, but I have a question. Is it necessary to have some initial condition or a contemporal node.
rmorales
Post by rmorales »
Well, net.update_beliefs() seems to go well, but then I have problems printing the posteriors:
Network written to colaborar_din.xdsl
Starting inferencing...
Posteriors with no evidence set:
P(Colaborar_G = Bajo) = 0.5
P(Colaborar_G = Medio) = 0.5
P(Colaborar_G = Alto) = 0.0
Traceback (most recent call last):
  File "modest_dynamic.py", line 180, in <module>
    InferenceOnNetwork(cn.get_network())
  File "modest_dynamic.py", line 146, in __init__
    self.print_all_posteriors(net)
  File "modest_dynamic.py", line 167, in print_all_posteriors
    self.print_posteriors(net, h)
  File "modest_dynamic.py", line 160, in print_posteriors
    value = net.get_outcome_id(node_handle, i)
RuntimeError: basic_string::_M_construct null not valid
Please, find attached the code and the resulting network.
modest_dynamic.txt
(5.48 KiB) Downloaded 11651 times
colaborar_din.xdsl
(10.69 KiB) Downloaded 10960 times
    def print_posteriors(self, net, node_handle):
        node_id = net.get_node_id(node_handle)
        if net.is_evidence(node_handle):
            print(node_id + " has evidence set (" +
                                     net.get_evidence(node_handle)) + ")")
        else :
            posteriors = net.get_node_value(node_handle)
            for i in range(0, len(posteriors)):
                p = posteriors[i]
                print("P(" + node_id + " = " + value + ") = " + str(p))
When i reaches 3, Python trying to get element that not exists. You should change
to
value = net.get_outcome_id(node_handle, i%net.get_outcome_count(node_handle))
rmorales
Post by rmorales »
I did the changes and it started working! Then I discovered all variables in the initial state of the net have the same probability distribution (0.5, 0.5, 0), so I initialized the top variable (CG) adding the following to my code
        t = self.stream_table(cpd.flatDist(3))
        net.set_node_definition(cg, t)
Then I found that there was not propagation on the initial state of the net, so I added a full definition for the initial state of the net,
        t = self.stream_table(cpd.incsub(2))
        net.set_node_definition(pg, t)
        net.set_node_definition(ag, t)
        t = self.stream_table(cpd.genesp())
        net.set_node_definition(ce, t)
        t = self.stream_table(cpd.join(cpd.genesp(),cpd.incsub(2)))
        net.set_node_definition(pe, t)
        net.set_node_definition(ae, t)
        t = self.stream_table(cpd.compevi())
        net.set_node_definition(ec, t)
        net.set_node_definition(ep, t)
        net.set_node_definition(ea, t)
and everything is fine now!
Some questions:
  1. Why beliefs initialization goes through 10 steps in time?
  2. How do I add evidences along time? (I have a guess on this one, but I ask it just in case I am wrong)
  3. Is there a way to recover the net at time t (all nodes probability distributions at time t)?
Regards.
It depends on Slice (Step) Count variable. You can change it by calling ex. net.set_slice_count(4) (four steps). Remember to update beliefs.
net.set_temporal_evidence(handle, slice, outcome)
If you want to get network definition, you should call get_node_temporal_definition method for each node. If your intention is to read the node values, use get_node_value method and read values corresponding to searched 't' value.
I hope it helps,
Piotr
rmorales
Post by rmorales »
Dear Piotr,
Thank you very much for your help. I can get the 16 time slices I wanted. However, I guess I am doing something wrong because the behaviour is not as expected. Given the temporal evidence
Competencia Tiempo Nivel
'e_proponer' 1 0
'e_aportar' 2 0
'e_proponer' 4 1
'e_aportar' 5 1
'e_colaborar' 7 1
'e_proponer' 10 2
'e_aportar' 11 1
'e_colaborar' 14 1
I get the following results with SMILE:
They are too flat, as if the network is almost no reacting to the evidence. Consider, for example, the same evidence on PGMPY
These results are more credible.
So, I am attaching the code, hoping you have time to have a look at it.
modest_dynamic.py.txt
(6.93 KiB) Downloaded 11284 times
def print_posteriors(net, node_handle):
        else :
            n = net.get_outcome_count(node_handle)
                value = value = net.get_outcome_id(node_handle, i%n)
                p = posteriors[i]
You should consider usage of has_temporal_evidence/is_temporal_evidence methods instead of is_evidence method. Slice count should be changed before adding evidence. Apart from these two things, the rest of code seems to be fine.
Could you tell me, how to reproduce these charts?
Genie shows, that node values change in time (Aportar_E at image).
rmorales
Post by rmorales »
Thank you! I would fix my is_evidence call. The charts are created using a spreadsheets (attached). And yes, the probabilities move, but too little. Consider the first pair or evidences on value 0 for e_proponer and e_aportar, they should have moved the probabilities much more than they are, as it happens with pgmpy. Unless in the SMILE case the temporal conditional are too strong.
bajoMedio16-smile.zip
(45.44 KiB) Downloaded 11372 times
bajoMedio16-pgmpy.zip
(33.33 KiB) Downloaded 10943 times
We have noticed that something is not quite right with network definition. You probably have not set nodes definition for t=0 (ex. Proponer_E)
It should be set with method set_node_definition (not like other slices - set_node_temporal_definition). Also notice, that in SMILE 'time' variable starts with 0 - if pgmpy starts with 1, you can get different results.
rmorales
Post by rmorales »
I have the opportunity to install Genie on a Windows machine, and I get a nice picture of my map:
I have followed the manual and revised the tables, and everything seems to be fine, bot the t = 0 definitions,
        net.add_arc(cg, pg)
        net.add_arc(cg, ag)
        net.add_arc(cg, ce)
        net.add_arc(pg, pe)
        net.add_arc(ce, pe)
        net.add_arc(ag, ae)
        net.add_arc(ce, ae)
        net.add_arc(ce, ec)
        net.add_arc(pe, ep)
        net.add_arc(ae, ea)
        # Non temporal conditionals. Time 0
        net.set_node_definition(cg,t)
as the temporal ones,
        # Temporal arcs
        net.add_temporal_arc(cg,cg,1)
        net.add_temporal_arc(pg,pg,1)
        net.add_temporal_arc(ag,ag,1)
        net.add_temporal_arc(ce,ce,1)
        net.add_temporal_arc(pe,pe,1)
        net.add_temporal_arc(ae,ae,1)
        # Conditionals that include temporal relations
        tpp = cpd.paspre()
        t = self.stream_table(tpp)
        net.set_node_temporal_definition(cg, 1, t)
        t = self.stream_table(cpd.join(cpd.incsub(2),tpp))
        net.set_node_temporal_definition(pg, 1, t)
        net.set_node_temporal_definition(ag, 1, t)
        t = self.stream_table(cpd.join(cpd.genesp(),tpp))
        net.set_node_temporal_definition(ce, 1, t)
        t = self.stream_table(cpd.join(cpd.genesp(),cpd.incsub(2),tpp))
        net.set_node_temporal_definition(pe, 1, t)
        net.set_node_temporal_definition(ae, 1, t)
Then I add the evidence, and update the beliefs.
	self.change_evidence_and_update(net, 'e_proponer', 1, 'Bajo')
        self.change_evidence_and_update(net, 'e_aportar', 2, 'Bajo')
        self.change_evidence_and_update(net, 'e_proponer', 4, 'Medio')
        self.change_evidence_and_update(net, 'e_aportar', 5, 'Medio')
        self.change_evidence_and_update(net, 'e_colaborar', 7, 'Medio')
        self.change_evidence_and_update(net, 'e_proponer', 10, 'Alto')
        self.change_evidence_and_update(net, 'e_aportar', 11, 'Medio')
        self.change_evidence_and_update(net, 'e_colaborar', 14, 'Medio')
        net.set_slice_count(17)
with
    def change_evidence_and_update(self, net, node_id, n_time, outcome_id):
        if outcome_id is not None:
            net.set_temporal_evidence(node_id, n_time, outcome_id)
        else:
            net.clear_temporal_evidence(node_id, n_time)
Yet, the model seems to be insensitive to to evidence. So I am wondering whether what I miss are initial conditions of some kind, or there is something deep wrong in the model.
colaborar_din.xdsl
(11.99 KiB) Downloaded 11057 times
Perhaps you should start setting evidence from time = 0 (decrease each t by one). I have done every step that you mentioned and calculations seems to be fine.
eg. e_colaboral values:
If you need more informations about DBNs, you can check GeNIe documentation: https://support.bayesfusion.com/docs/Ge ... ction.html
rmorales
Post by rmorales »
Well, it looks like there is some differences in understanding what a DBN is. I was thinking on something that evolves in time; i.e. conditional probabilities in nodes in slice t+1 depend only on conditional probabilities in nodes in the same slice and slice t. So evidences for e_proponer = 0 and e_aportar = 0 in slices 1 and 2 would make conditional probabilities for nodes 'Proponer_E' and 'Aportar_E' to "move" towards 0. But it seems to me now that what the system tries to do is to consider all the slices and evidences all together, as a large static BN, and considering all evidence together.
Is that the case?
Your temporal arcs have order 1, therefore your CPTs in t+1 are conditioned on nodes in t+1 and t. However, the calculated posterior probabilities depend on the entire unrolled network and the evidence set. To calculate the posteriors, SMILE unrolls the network into a static BN containing the specified number of slices, performs inference and copies the results into original DBN. You can use the 'Unroll' command in GeNIe to visualize the process.
For more info, see Using GeNIe/Dynamic Bayesian Networks chapter in GeNIe manual.
