Using SMILE with Visual Studio 2015 C++
jdtoellner
Post by jdtoellner »
There are some hard to find configurations I had to do to get SMILE to work with Visual Studio C++.
Here are the instructions I followed.
First, download SMILE for Visual Studio 2015; the 64 bit version. Here's the download page: https://download.bayesfusion.com/files. ... ness#SMILE
SMILE 64 Bit.JPG (14.4 KiB) Viewed 282528 times
That link points to a ZIP file. Unzip the files into a folder in the Visual Studio folder. (These files can go anywhere.)
Visual Studio Folders.JPG (15.34 KiB) Viewed 282528 times
Create a new project in Visual Studio.
Visual Studio New Project.JPG (53.56 KiB) Viewed 282528 times
jdtoellner
Re: Using SMILE with Visual Studio 2015 C++
In the Solution Explorer window right-click on SMILE Sample Application (or whatever you named your application).
Visual Studio Solution Explorer.JPG (29.79 KiB) Viewed 282523 times
Select Properties.
Visual Studio Solution Explorer Properties.png (18.98 KiB) Viewed 282523 times
On the properties page select VC++ Directories.
Visual Studio Properties VC Directories.JPG (75.08 KiB) Viewed 282523 times
jdtoellner
Click on the field next to Include Directories and select <Edit...>.
Visual Studio Include Directories.png (26.05 KiB) Viewed 282523 times
Click on the Folder icon in this window.
Visual Studio Include Directories Folder Selector.JPG (31.91 KiB) Viewed 282523 times
Then click on the ellipses (...).
Visual Studio Include Directories Folder Selector 2.JPG (31.2 KiB) Viewed 282523 times
jdtoellner
From here you'll navigate to the SMILE folder you unzipped.
Visual Studio Include Directories Folder Selector 3.JPG (57.95 KiB) Viewed 282523 times
Select the SMILE folder you created from the ZIP file.
Visual Studio Select SMILE Folder.JPG (48.58 KiB) Viewed 282523 times
Click OK here.
Visual Studio Include Directories Folder Selector 4.JPG (34.59 KiB) Viewed 282523 times
jdtoellner
You'll need to do the same for Library Directories.
Visual Studio Properties VC Directories Library.JPG (78.35 KiB) Viewed 282523 times
Follow the same instructions you did for the Include folder.
When you're done with that click OK here.
Visual Studio Properties VC Directories OK.JPG (68.32 KiB) Viewed 282523 times
You can now #include smile.h in your code.
Visual Studio Include SMILE.JPG (26.04 KiB) Viewed 282523 times
Gary
Post by Gary »
I use the Chinese version of VS2010, the same way?
Jon,
Thanks for writting this info down. To build up on this, let me add that there's an alternative way of specifying the include and library directories:
1. for include directories, go to Project Settings, C/C++, General and set 'Additional Include Directories'.
2. for library directories, go to Project Settings, Linker, General and set 'Additional Library Directories'.
jdtoellner
For some reason this stopped working. I can't get VS to find include files. I'm having to resort to putting them in the project code folder.
VS works fine for projects I've already created. It stopped working for new projects.
Did you try to use the 'Additional Include Directories' option in C/C++|General settings?
jdtoellner
Yes. I tried this both ways: in VC++ Directories and in C/C++ General.
I'll chalk this up to either a Visual Studio bug or in my inability to use Visual Studio. It's not holding me up. It's just inconvenient.
Maybe it's an issue with OneDrive (your screenshots had directories there).
jdtoellner
I figured out the problem. There's a Configuration option on the Property page. I had inadvertently selected Release and should have selected Degub.
