How to set temporal probability matrix
petcai
Post by petcai »
How can you set temporal probability when a node has a temporal arc to another node? I can see the node definition has a method call SetTemporalDefinition. It takes order and double array as parameters which seems only work for temporal arc to the node itself. Thanks.
Re: How to set temporal probability matrix
petcai wrote:How can you set temporal probability when a node has a temporal arc to another node? I can see the node definition has a method call SetTemporalDefinition. It takes order and double array as parameters which seems only work for temporal arc to the node itself. Thanks.
It should work for all types of temporal arcs. If you experience further problems, cast the definition to DSL_cpt and use one of its SetTemporalProbabilities methods.
