How to set temporal probability matrix
How can you set temporal probability when a node has a temporal arc to another node? I can see the node definition has a method call SetTemporalDefinition. It takes order and double array as parameters which seems only work for temporal arc to the node itself. Thanks.
Re: How to set temporal probability matrix
It should work for all types of temporal arcs. If you experience further problems, cast the definition to DSL_cpt and use one of its SetTemporalProbabilities methods.petcai wrote:How can you set temporal probability when a node has a temporal arc to another node? I can see the node definition has a method call SetTemporalDefinition. It takes order and double array as parameters which seems only work for temporal arc to the node itself. Thanks.
