Hi!
Is it possible to select pure loopy belief propagation as algorithm even if it is not correct, only to see its result?
-Jochen
Loopy Belief Propagation
Re: Loopy Belief Propagation
It should be possible - did you try it?Jochen0x90h wrote:Is it possible to select pure loopy belief propagation as algorithm even if it is not correct, only to see its result?
Jochen0x90h
In Java the BayesAlgorithmType has a public static final int LBP = 9; which must be Loopy Belief Propagation if you say that it is supported. How do you set iteration count and damping?
Unfortunately, jSMILE does not expose the DSL_network::SetLBPParams method which controls LBP-specific parameters. However, the sample count is accessible through Network.get/setSampleCount.Jochen0x90h wrote:In Java the BayesAlgorithmType has a public static final int LBP = 9; which must be Loopy Belief Propagation if you say that it is supported. How do you set iteration count and damping?
Jochen0x90h
Have you any experience with residual belief propagation? Does it converge to a solution on networks where synchronous loopy belief propagation starts to oscillate?
As far as I know, we don't have LBP accessible to the users in GeNIe or SMILE. We have it internally as part of the EPIS-BN algorithm. We have Hybrid LBP, which is an experimental algorithm for networks with continuous variables. We have no experience with residual belief propagation. Do you think we should look at it?
