Loopy Belief Propagation
Jochen0x90h
Post by Jochen0x90h »
Hi!
Is it possible to select pure loopy belief propagation as algorithm even if it is not correct, only to see its result?
-Jochen
Re: Loopy Belief Propagation
Jochen0x90h wrote:Is it possible to select pure loopy belief propagation as algorithm even if it is not correct, only to see its result?
It should be possible - did you try it?
Jochen0x90h
In Java the BayesAlgorithmType has a public static final int LBP = 9; which must be Loopy Belief Propagation if you say that it is supported. How do you set iteration count and damping?
Jochen0x90h wrote:In Java the BayesAlgorithmType has a public static final int LBP = 9; which must be Loopy Belief Propagation if you say that it is supported. How do you set iteration count and damping?
Unfortunately, jSMILE does not expose the DSL_network::SetLBPParams method which controls LBP-specific parameters. However, the sample count is accessible through Network.get/setSampleCount.
Jochen0x90h
Have you any experience with residual belief propagation? Does it converge to a solution on networks where synchronous loopy belief propagation starts to oscillate?
As far as I know, we don't have LBP accessible to the users in GeNIe or SMILE. We have it internally as part of the EPIS-BN algorithm. We have Hybrid LBP, which is an experimental algorithm for networks with continuous variables. We have no experience with residual belief propagation. Do you think we should look at it?
