Dear sir or madam,
I tried to import pysmile in another computer with Windows system, I download the pysmile package on the website: https://download.bayesfusion.com/files. ... y=Academia, I download the pysmile-1.6.0-win-x64-python-3.7 academic.zip and uncompress this folder, then put the pysmile.pyd into a new folder like below "WeChat Image_20210307013204.png" figure, then i create a new python file. it reminds me: ImportError: DLL load failed while importing pysmile: the specified module could not be found.
then I tried to pip install pysmile by pip install --index-url https://support.bayesfusion.com/pysmile-A/ pysmile, i get the same error;
I have tried to use pip install --index-url https://support.bayesfusion.com/pysmile-B/ pysmile, then i get the same error when I import pysmile.
the procedure as below figure1.
I also tried to create a new empty folder without anything, then create a python folder, i also get the error, it reminds me SyntaxError: invalid syntax. the error like figure 3.
the native pysmile is not installed in the local machine.
all the procedure run in Anaconda, Jupyter, I also test the same procedure by using the pysmile version that pysmile-1.6.0-win-x64-python-2.7 academic.zip
Could you please tell me why that happens? and how can I solve this problem on another computer?
Best regards!
Yajie Yang
- 3.png (21.83 KiB) Viewed 56473 times
- 1.png (49.62 KiB) Viewed 56473 times
- WeChat Image_20210307013204.png (13.42 KiB) Viewed 56473 times
Re: ImportError: DLL load failed while importing pysmile: the specified module could not be found
At first, you have to unistall pysmile version 0.2
Second - to get the correct version from our index, use the command below:
Note that PySMILE may not be fully compatible with the Anaconda - we recommend using the official binaries from python.org
pip uninstall pysmileCode: Select all
pip install --no-cache-dir --index-url https://support.bayesfusion.com/pysmile-B/ pysmileRe: ImportError: DLL load failed while importing pysmile: the specified module could not be found
I'm facing the same problem while trying to install pysmile for a python 3.9 (not anaconda)
I'm using a virutal environment and form within the environment I run the command:
It successfully installs pysmile and I can find the (pysmile-1.6.2.dist-info) directory inside the (site-packages) directory. I also added the pysmile_license.py file to the current working directory. However, when I import pysmile I get the error that:
pip install --no-cache-dir --index-url https://support.bayesfusion.com/pysmile-A/ pysmileCode: Select all
ImportError: DLL load failed while importing pysmile: The specified module could not be found.-
Have you tried to run PySMILE without using venv? Also - could you check if "home" variable in pyenv.cfg file (top of venv folder structure) points to directory which contains python39.dll file?
I didn't actually try to use PySMILE outside a venv (I prefer to make this option the very last resort, in the end, this is not a very pythonic practice).
I checked the contents of the pyenv.cfg file and they are as follows:
So it shows that it is pointing to the folder that contains the python3.9.dll
Another side point, I've previously faced a problem with learning a model with Noisy-Max nodes, and you generously shared a pre-releasable version of SMILE that handles this issue. So my question is, does the current pySMILE version accessible through your index contains that fix?
Link of the thread discussing the Noisy-MAX issue: viewtopic.php?f=2&t=4728&p=10613#p10613
home = C:\Users\z5229837\AppData\Local\Programs\Python\Python39
include-system-site-packages = false
version = 3.9.2Another side point, I've previously faced a problem with learning a model with Noisy-Max nodes, and you generously shared a pre-releasable version of SMILE that handles this issue. So my question is, does the current pySMILE version accessible through your index contains that fix?
Could you try to use PySMILE outside a venv? For testing purposes only - to check if it is really a problem of the virtual environment. I wasn't able to recreate an error (both inside and outside venv) so any additional information will be helpful.
PySMILE 1.6.2 should contain learning fix.
Thanks for your reply Piotr,
I was actually able to solve the problem by removing the venv and recreate a new one, then reinstall pysmile.
Thanks again.
Thanks again.
