Dear colleague,
In GeNIe, what is the metric of sensitivity index? It is kind of hard to interpret the sensitivity analysis results without knowing how big or small it should be or compare with.
Thank you for the help.
Cody
metric for sensitivity index
Re: metric for sensitivity index
You can find a mathematical description of GeNIe's implementation of sensitivity analysis in the ''Sensitivity analysis in Bayesian networks" chapter of GeNIe manual. The chapter number is 6.2.9 in the current PDF release of the manual (3.0.R2). For your convenience, here's the direct link to the HTML chapter:
https://support.bayesfusion.com/docs/Ge ... itybn.html
This information is also available in the GeNIe's local help file (press F1 in the program).
