[.NET] SMILE.NET compatible with .net compact framework?
klkim
Post by klkim »
SMILE.NET is a wrapper class used in .net framework, I think. Is it possible to use SMILE.NET in ".net compact framework"?
I have tested smilenet.dll in Windows Mobile 6 Professional Emulator via VS2005, and there was a "MissingMethodException". How can I use the library in .net compact framwork (that is Windows Mobile 5.0 or 6 in managed fashion just like using C#)? Re-compile and re-build from the scratch is necessary? Is this job a harder one than using native C++, pocketSMILE headerfiles and smile.lib?
Thanks in advance.
Re: [.NET] SMILE.NET compatible with .net compact framework?
klkim wrote:SMILE.NET is a wrapper class used in .net framework, I think. Is it possible to use SMILE.NET in ".net compact framework"?/quote]
No, because SMILE.NET contains native x86 code calling directly into Win32 API.
I don't think you can just rebuild Smile.NET for the compact framework. I guess your best shot is to build native DLL with PocketSMILE exposing
high level functionality specific to your project, then use P/Invoke.
