Generate Data File
zimity
Generate Data File
Post by zimity »
Please, which method is used to generate data set that is representative of the network. What supporting literature can I quote in my thesis.
Re: Generate Data File
The algorithm iterates over nodes in the network using partial ordering. The outcome of each node is determined by using the pseudorandom uniform generator applied to the CPT column based on the outcomes of node's parents.
If you have 'Bias samples by existing evidence' option enabled, the sample will be rejected when generated outcome of the evidence node is not the evidence outcome.
