How to avoid error -42 in UpdateBeliefs in jSMILE
yuriy
Post by yuriy »
I'm working with a network of a little less than couple hundred nodes, all of them discrete CPTs, and in my code I need to compute probabilities of the form P(X|Y) many times where Y isn't always a parent of X.
I do this by doing
net.clearAllEvidence();
net.clearAllTargets();
net.setEvidence( contrast, tval );
net.setTarget( child, true );
net.updateBeliefs();
p[tval] = net.getNodeValue( child )[cval];
to get P( child = cval | contrast = tval ).
Sooner or later I end up getting
SMILE error -42 in function UpdateBeliefs
From looking at errors.h I see that -42 indicates an out of memory error.
Is there anything else I can do to reduce the amount of memory needed by SMILE?
Is something getting accumulated in memory from making these calls a lot that I could clear?
Is there any way to force SMILE to use more memory, or force the JVM to give SMILE more memory?
How does SMILE determine that it is out of memory to trigger error -42?
Re: How to avoid error -42 in UpdateBeliefs in jSMILE
You already gave SMILE the opportunity to limit the memory usage by calling setTarget. Your other options are switching to approximate inference or restructuring the network.
No, as far as I know we don't have a memory leak in the inference code. By design there are no cached structures left over after updating the beliefs.
JVM doesn't give SMILE memory, since the core library is native C++. At best you can try to reduce the max Java heap size to ensure that more RAM is left available. I believe this won't be enough.
-42 comes from the triangulation phase; it's returned when total size of cliques exceeds available memory. Please note that this applies only to clustering, which is the default exact inference algorithm.
yuriy
Post by yuriy »
Thanks for your help,
I've found out that approximate inference helps, but I'd like to only have to use it when exact inference fails. I've written the following code to do that:
    final static int[] ALGOS = { // Algorithms to try, in order.
                //Network.BayesianAlgorithmType.Lauritzen,
                Network.BayesianAlgorithmType.EpisSampling//,
                //Network.BayesianAlgorithmType.HeuristicImportance,
                //Network.BayesianAlgorithmType.Henrion,
                //Network.BayesianAlgorithmType.SelfImportance,
                //Network.BayesianAlgorithmType.LSampling,
                //Network.BayesianAlgorithmType.AisSampling,
                //Network.BayesianAlgorithmType.BackSampling,
                //Network.BayesianAlgorithmType.Pearl,
                //Network.BayesianAlgorithmType.LBP
    private void updateBeliefs() throws SMILEException{
        SMILEException lastException = null;
        for( int algo : ALGOS )
            try{
                net.setBayesianAlgorithm( algo );
                return; // If we reach here updating was successful.
            }catch( SMILEException e ){
                LOG.trace("Algorithm "+algo+" failed.");
                lastException = e;
        if( lastException != null ) throw lastException;
Then I call my updateBeliefs method whenever I would normally call net.updateBeliefs. The idea is that if an algorithm in the list fails, the next one in the list is tried.
Something strange is happening though: The way I have everything right now, with all except EpisSampling commented, I don't get any errors, but if I uncomment Lauritzen, sometimes only Lauritzen fails and sometimes they both fail.
It looks like calling updateBeliefs with the other algorithm is affecting the ability to run it with EpisSampling. Any insight to why this is happening?
The behavior you've described suggests some memory leaks on the error return path from exact inference and/or fragmentation of the native heap.
