I attempted to drag and drop in the Data->Learn Parameters box and the drag and drop doesn't work?
Also, there is not file tutorial17.xdsl in my example directory?
Tutorial 16 Parameters & Tutorial 17
Re: Tutorial 16 Parameters & Tutorial 17
My best guess is that you're trying to change node-column matching in the list of matches. This list only allows you to change the node outcome-column value assignments (which are represented by subitems in the list). If this is the case, and you want to use different node-column matchings, press the 'Reset' button or drag node or column to leftmost or rightmost list.gmb wrote:I attempted to drag and drop in the Data->Learn Parameters box and the drag and drop doesn't work?
You're right. I'll notify people responsible for the documentation.gmb wrote:Also, there is not file tutorial17.xdsl in my example directory?
