Hello ,
Can i use the Genie as tool which get as input data table with attributes and give as output the Bayesian network that represent the dependency between these attributes ?
Can i access/use the Genie Output from C# ?
Thanks ,
Boris
Bayesian Network
Re: Bayesian Network
Yes, check out the GeNIe's learning features.Can i use the Genie as tool which get as input data table with attributes and give as output the Bayesian network that represent the dependency between these attributes ?
Yes, you can use Smile.NET with C#.Can i access/use the Genie Output from C# ?
