JSmile and Exist
JMac
JSmile and Exist
Post by JMac »
I'm trying to combine jsmile with an exist database to store the networks (xdsl files). Is there an easy way to get loadfile to access an xml object directly? My other two options - parsing the xml object and building the network, or saving the xml locally to have jsmile load it in - are not appealing.
Any suggestions?
J
Re: JSmile and Exist
JMac wrote: Is there an easy way to get loadfile to access an xml object directly?
I assume you're referring to Network.readFile in your original post. Since this is just a thin wrapper over C++ SMILE method, it's not possible to perform network I/O without going to filesystem level. I'd go for file located in temp directory.
