Getting expectation from distirbution node
kjung2
Post by kjung2 »
I have an equation node of a distribution of possible infection rate = p.
I have another equation node of number of sampled = n.
These two nodes connect to an equation node - bernoulli(n,p) -> gives a distribution of positive cases.
I want to create an equation node that is 1 (quarantine) if expectation of positive case >=1 and 0 otherwise... but I can't figure out a way to do so (this quarantine node also becomes a distribution).
Is there a way to convert distribution to its expectation in the subsequent node?
Many thanks.
Re: Getting expectation from distirbution node
You can operate on values but not on their statistical properties (i.e., results) in your equations. Please keep in mind that a Bayesian network is equivalent to a system of simultaneous equations. Your new variable could have a conditional statement that compares the number of positive cases to something (e.g., function If()) but you cannot refer in your equation to the expectation of another node.
kjung2
Post by kjung2 »
Thank you so much!
