Network size limitation of SMILE package
BayesFusionUser123
Post by BayesFusionUser123 »
Dear Community,
I am following the PDF version of the tutorial for SMILE wrappers, specifically for python language.
I am trying SMILE package on our real-world dataset.
Our dataset has 1654 nodes, 2965 edges.
Among the 1654 nodes, there are 605 continuous variables and 1049 categorical variables.
To make learning parameter EM algorithm work on this network, I discretize all continuous variables into 5 bins.
After I learn the parameter of this network from a dataset. I try to print out the posterior of a target variable.
I tried the following code:
hybrid_net.update_beliefs()
print_posteriors(hybrid_net, 0)
It gives error message like below:
SMILEException Traceback (most recent call last) Cell In[84], line 1
----> 1 hybrid_net.update_beliefs() 2 print_posteriors(hybrid_net, 0)
SMILEException: SMILE Error -42 in function Network.UpdateBeliefs
I checked the error code and found:
https://support.bayesfusion.com/docs/SM ... codes.html
The -42 means `DSL_OUT_OF_MEMORY`
My question:
Does it means SMILE cannot deal with network of this size?
What is the largest size of network can SMILE deal with?
How can I solve this issue?
Thank you very much.
Re: Network size limitation of SMILE package
Error -42 is caused by insufficient memory in exact inference algorithm. This algorithm creates temporary data structure (the join tree), which can become very large, depending on the connections in the network.
You can switch to approximate sampling inference (EPIS), or set explicit targets in the network if you're only interested in the subset of node probabilities.
BayesFusionUser123
"set explicit targets in the network if you're only interested in the subset of node probabilities"
print_posteriors() function is like below:
def print_posteriors(net, node_handle):
    node_id = net.get_node_id(node_handle)
    if net.is_evidence(node_handle):
        print(f"{node_id} has evidence set ({net.get_evidence_id(node_handle)})")
    else :
        posteriors = net.get_node_value(node_handle)
        for i in range(0, len(posteriors)):
            print(f"P({node_id}={net.get_outcome_id(node_handle, i)})={posteriors[i]}")
When I run print_posteriors(net, 0), it is only for target variable with node_handle 0
I want to clarify that it looks like it is not that I did not set explicit targets that cause memory issue.
It is the update_beliefs() function call that reports out of memory error.
Below is my test on a small network:
manipulate_net = pysmile.Network()
# load the network with learned parameters.
manipulate_net.read_file("./simulated_data/simulated_data_em_cont.xdsl")
# If I call print_posteriors only for target 2, it will reports error
print_posteriors(manipulate_net, 2)
Cell In[33], line 1
----> 1 print_posteriors(manipulate_net, 2)
Cell In[22], line 6, in print_posteriors(net, node_handle)
      4     print(f"{node_id} has evidence set ({net.get_evidence_id(node_handle)})")
      5 else :
----> 6     posteriors = net.get_node_value(node_handle)
      7     for i in range(0, len(posteriors)):
      8         print(f"P({node_id}={net.get_outcome_id(node_handle, i)})={posteriors[i]}")
SMILEException: SMILE Error 1 in function Network.GetValue
I must firstly update_beliefs() and then print_posteriors only for target variable.
manipulate_net.update_beliefs()
Then it gives correct result:
P(T=T___0)=0.54084
P(T=T___1)=0.45916
Below is the situation on a real world network
If I run
hybrid_net_with_para.update_beliefs()
print_posteriors(hybrid_net_with_para, 1)
The hybrid_net.update_beliefs() that cause it to have -42 error.
Cell In[144], line 1
      2 posteriors = hybrid_net.get_node_value(1)
(2)
(2.1)
Could you please point me to some tutorial with sample code or document to do "approximate sampling inference (EPIS)"?
(2.2)
I found that SMILE wrapper document lacks lots of information. Did I missed anything, any other document resource?
I have read the EPIS related material in the GeNIe document. But I cannot find any documentation in the wrapper document about how to set EPIS.
In the Network methods list I found two methods get_bayesian_algorithm() and set_bayesian_algorithm()
I use get_bayesian_algorithm() to get current algorithm, it prints <BayesianAlgorithmType.LAURITZEN: 0>.
Could you please show me how to set it to EPIS?
To switch the inference algorithm to EPIS use set_bayesian_algorithm with pysmile.BayesianAlgorithmType.EPIS_SAMPLING:
net.set_bayesian_algorithm(pysmile.BayesianAlgorithmType.EPIS_SAMPLING)
Regarding explicit relevance targets in the network, here's the info from the wrappers manual
Network.updateBeliefs throws an exception with error code -42 if the temporary data structures required to
complete the inference take too much memory. In such case, or if the inference takes too long, consider taking
advantage of SMILE's relevance reasoning layer. Relevance reasoning runs as a preprocessing step, which can
lessen the complexity of later stages of inference algorithms. Relevance reasoning takes the target node set into
account, therefore, to reduce the workload you should reduce the number of nodes set as targets if possible. Note
that by default all nodes are targets (this is the case when no nodes were marked as such). If your network has
1,000 nodes and you only need the probabilities of 20 nodes, by all means call Network.setTarget on them.
