Annotation in rSMILE
davidfdavis
Is there a way to programmatically insert text as annotations using rSMILE? This is a good place for node textual definition that is available through my R code. Cutting and pasting would be tedious.
Re: Annotation in rSMILE
rSMILE provides the setNodeDescription method. It allows you to associate any text with a selected node in the network.
You can get value by calling:
net$setNodeDescription("NodeId", "This text will be associated with node NodeId.")
desc <- net$getNodeDescription("NodeId")
davidfdavis
> BN$setNodeDescription("T1", "This text will be associated with node NodeId.")
Error in BN$setNodeDescription("T1", "This text will be associated with node NodeId.") :
RSmile error occured
SMILE Error Occured. Passed object is NULL
Could you share rest of that code and version of R and rSMILE? This method should work seamlessly.
BTW, if you want to move this conversation into private space, email me or send me a forum PM.
davidfdavis
It now works as advertised. The only thing I did differently (that I am aware of :)) was to put the NodeId into a variable first. Now it works fine. Many thanks for your patience. I am still interested in where in the documentation this would have been found.
