Font size of axes values
Hello, I have equation nodes in my network which I want to display as bar charts. I was able to change the size of the node label but the axes font size remains small. Is it possible to change the font size of the axes and axes labels in Genie?
Re: Font size of axes values
Currently there are no formatting options available to axis and axis labels in GeNIe.
Is the font size too small to be visible?
Yes, the font size is not visible. I have 12 nodes in my network and wanted to have a screenshot for my presentation. As I said I can increase the size of the node label but the axes numbers are too small. Thanks for your response.
We have added a network property to control the sizes of axis labels in node barchart. The next GeNIe release will go public next week, and you will be able to specify the point size of the font.
Regarding the screenshot use in the presentation - you can use the Copy command in GeNIe, then paste into any graphical program, then zoom in. Alternatively, you can zoom in directly in GeNIe.
