Copy and paste problem with GeNIe 5
Post by PCherubini »
the newly released GeNIe version 5 does not allow to copy networks from GeNIe and paste them as TIFF images to microsoft word (nor microsoft power point; I did not check for other softwares). Genie 4.1 still allowed it. I remember having reported a similar bug for the transition between two sub-versions of GeNIe 4.0 (on march 24 2023), and you were able to solve it rather switfly; perhaps it's the same kind of bug, in case this helps.
Thank you for the otherwise excellent new development!
Re: Copy and paste problem with GeNIe 5
There were no changes in the bitmap copy/paste code between versions 4.1 and 5.
If you're running GeNIe with Crossover on Mac, the solution from the previous thread was to install GeNIe into 32-bit bottle.
Yes, sorry for having wasted your time. I forgot that the solution the previous time was 32-bit installation. Now it works, thanks.
