Log-transformation data
How do I log-transform data in GeNIe to reduce skewness of my probability distributions?
Re: Log-transformation data
You can't do it in GeNIe. What you can do is transform your data in Excel by creating for a variable x a new variable/column named, e.g., log_x) and then save the file as .CSV and load it into GeNIe. You can use log_x instead of x in learning.
Thanks Marek. I will try that and get back if I need anymore help. Thanks again.
Chisha
Chisha
