Problem installing pysmile in a conda environment
EAly
Post by EAly »
I'm having issues installing SMILE on a macOS.
When I try to install it from the online repo using:
python -m pip install --index-url https://support.bayesfusion.com/pysmile-A/ pysmile
I get the following error:
ERROR: Could not find a version that satisfies the requirement pysmile (from versions: none)
ERROR: No matching distribution found for pysmile
And I don't know how can I install it using the
pysmile.so
file (in the downloadable
pysmile-academic-2.0.10-macosx-python-3.10.tar.gz
I would also appreciate some guidance on how to install pysmile in a certain conda environment and not in the base environment
Can you provide any help with that please? Thanks in advance for your help
Re: Problem installing pysmile in a conda environment
Post by piotr [BayesFusion] »
Can you check the Python version in your Conda environment?
python --version
PySMILE is not currently compatible with Python 3.11 - an update is on the way and will be available soon.
