Will the network structure be too complex to perform parameter learning?
philrain
Post by philrain »
After obtaining the network structure through Bayesian search, I tried to use parameter learning, but the software crashed directly. Is it because the network structure is too complicated? There are a total of 87 nodes in the network, and each point is set to have less than 5 parent nodes.
Re: Will the network structure be too complex to perform parameter learning?
I suspect one or more nodes are based on a data column(s) with very large number of distinct values. If your data file has a unique identifier column, do not include it.
