NameError: name 'self' is not defined
bahman
Post by bahman »
HI;
import pysmile
import pysmile_license
net = pysmile.Network()
e = self.create_cpt_node(net,
    "Economy", "State of the economy",
    ["Up","Flat","Down"],
    160, 40)
s = self.create_cpt_node(net,
    "Success", "Success of the venture",
    ["Success","Failure"],
    60, 40)
f = self.create_cpt_node(net,
    "Forecast", "Expert forecast",
    ["Good","Moderate","Poor"],
    110, 140)
def create_cpt_node(self, net, id, name, outcomes, x_pos, y_pos):
    handle = net.add_node(pysmile.NodeType.CPT, id)
    net.set_node_name(handle, name)
    net.set_node_position(handle, x_pos, y_pos, 85, 55)
    initial_outcome_count = net.get_outcome_count(handle)
    for i in range(0, initial_outcome_count):
        net.set_outcome_id(handle, i, outcomes[i])
    for i in range(initial_outcome_count, len(outcomes)):
        net.add_outcome(handle, outcomes[i])
    return handle
    net.add_arc(e, s)
net.add_arc(s, f)
net.add_arc("Economy", "Forecast")
successDef = [
    0.3, # P(Success=S|Economy=U)
    0.7, # P(Success=F|Economy=U)
    0.2, # P(Success=S|Economy=F)
    0.8, # P(Success=F|Economy=F)
    0.1, # P(Success=S|Economy=D)
    0.9  # P(Success=F|Economy=D)
net.set_node_definition(s, successDef)
print("Posteriors with no evidence set:")
net.update_beliefs()
self.print_all_posteriors(net)
i want to run this code but i get this error why ?
      4 net = pysmile.Network()
      5
----> 6 e = self.create_cpt_node(net,
      7
      8     "Economy", "State of the economy",
is "self" have defenition like net ?
thank you
Re: NameError: name 'self' is not defined
Post by piotr [BayesFusion] »
You are trying to run modified Tutorial1 code - in that code self refers to object of Tutorial1 class. Try to remove all self calls from your code and move create_cpt_node fuction definition before calling it.
You can learn more about self from here: https://www.w3schools.com/python/gloss_python_self.asp
bahman
Post by bahman »
HI piotr
whould you check this ? is it true ? i still have error
    net.set_node_position(handle)
    return handle
e = create_cpt_node(net,
    160, 40)
s = create_cpt_node(net,
    60, 40)
f = create_cpt_node(net,
    110, 140)
net.add_arc(e, s)
net.add_arc(s, f)
successDef = [
    31     ["Up","Flat","Down"],
     32
---> 33     160, 40)
     34
     35 s = create_cpt_node(net,
TypeError: create_cpt_node() missing 1 required positional argument: 'y_pos'
thank you
Remove self from create_cpt_node arguments.
def create_cpt_node(net, id, name, outcomes, x_pos, y_pos):
Also - I can't see print_all_posteriors function declaration. You have to copy that function from our tutorial.
