Crash DBN
macsermkiat
Crash DBN
Post by macsermkiat »
Hi, I'm using Genie for Academic for my PhD thesis.
It just crashed recently, though it was able to learned parameter in the past, but I'm not sure why it happened.
Right now it just crashed every time, though I tried to reduced the nodes , timesteps, and states.
The data is 270k rows with 100+ columns (including the time series)
Here I attached the network file.
Stroke-DBN-temp2.xdsl
(46.55 KiB) Downloaded 1284 times
Here is an example data file
example.csv
(5.17 KiB) Downloaded 1000 times
Thank you
macsermkiat
Re: Crash DBN
Hi
I found a cause of the problem; since I set one of the target variable as -1, it crashed.
If I changed to other number or text, it worked fine. So is this considered some kind of bugs?
Thank you
Re: Crash DBN
Did you call SetEvidence and specified -1 as the outcome index?
macsermkiat
Re: Crash DBN
No, I mean my outcome variable (I didn't explicit set it as the target) has 4 values.
One of it was -1, so I changed it to something else (e.g, 99 , or "NA"), it worked fine.
