Complex network +50 nodes
gabrielareis
Post by gabrielareis »
I'm new to using genie/SMILE (more specifically using rSMILE).
I have a problem of risk assessment of a Water Supply System and I have more than 50 risks (i.e. more than 50 nodes). I gave up using Genie because the CPT would be way complex and I read that SMILE would support networks with until 110 nodes or something. However, by reading the Manual and completing the tutorials, I can't seem to identify how to use complex networks using rSMILE (it does not seem to be different than Genie).
Does anyone have any suggestions or material that could help me with that?
Re: Complex network +50 nodes
This is not true - SMILE will support networks with thousands of nodes - see the model with 2000+ nodes in our interactive web repository:
https://repo.bayesfusion.com/network/pe ... nosis.xdsl
gabrielareis
Thank you for the link, I've actually seen the image of this network a few times already but hadn't seen the actual model to interact with. My main question is: how do you do with the CPT? This still looks foggy to me.
You can examine the machine diagnosis model interactively through our model repository. You can see each CPT when playing with the model. Here is the address of the repository, just in case you missed it:
http://repo.bayesfusion.com/
The address provided to you by Tomek will lead you directly to the model in question.
