I have read other posts about this and know that you will get this error when the smile_license.h is corrupt, expired or otherwise incorrect.
How can I handle this error or exception?
I am developing a flutter app (not for public) that uses the SMILE Engine. When I compile the code and have the app on a device, it crashes when the license is expired. Instead I would love to catch the error and handle it instead of my app crashing.
I tried to use a try...catch block around the first occurence of any SMILE related instruction with no success.
I tried to compile my code in a static library such that I could call the library and if the result is "SMILE INITERR ..." I could handle the error that way. This may have failed because I have done it wrong for my lack of understanding C++ compiling and linking especially. I tried it with a .exe as well, like calling a third party API or in this case software for the result but still no success.
My code builds, but whenever I run it, I can not get anything else from it than SMILE INITERR 0E or 0D...
Furthermore I would love to write a test case with google test that tests the error handling (if it works). I think this might be possible with including different smile_license.h depending on the test case with ifdef etc. but I wouldn't know how to. This is not my primary problem, as long as I can keep it from crashing its fine.
I am using Visual Studio 2019, with SMILE Core in C++.
For the app I use the newest version of flutter and dart. The code is used with dart:ffi.
SMILE (Visual C++) INITERR 0E, Error handling, Flutter, Dart, C++
Re: SMILE (Visual C++) INITERR 0E, Error handling, Flutter, Dart, C++
INITERR 0E is the code for expired licensing key.
INITERR 0D is caused by mismatched academic/business licensing key (an attempt to use the academic key with business binaries, for example).
Thank you but I figured that much out already by testing it myself. I looked at similar posts in this forum that explained some of the error codes already.
But as I said, the main problem I am facing is that it is not testable and usable in my app due to it crashing if there is a problem with the license.
Your problem with the license is directly related to the expiration of the license key. For long-term use you'll need a deploment license. For SMILE Business, you need a commercial deployment license. If you're an academic user and BayesFusion's academic license (https://download.bayesfusion.com/license_academic.txt) applies to your project, send us an email from your university account, as indicated at our download site and in SMILE Manual.it is not testable and usable in my app due to it crashing if there is a problem with the license.
Yes I understand that this is the case. So what you are saying is, that it is not possible to test this?
When I want to publish the app or use it somewhere outside of my dev environment I will look into the licensing, but until then I would like to have SMILE in my app, with an expired or corrupt license and when I try to use it get an exception that I can handle. Instead I now have an app that crashes.
Are you using Business or Academic edition of SMILE?
I am using Academic edition of SMILE.
