Network export as vector file
da_genie
Post by da_genie »
when I want to use the created graphs in presentations or publications I have to print it as a PDF and make screenshots from the PDF and copy/paste it in the documents.
Is there any way to generate a view as a vector file (PDF, SVG, EPS, EMF/WMF, ...)?
Thank you in advance
Re: Network export as vector file
GeNIe copies the network to the clipboard in multiple formats when you use Ctrl+C or the Copy command from the toolbar/menu. If your program supports the vector copy, it should work. Note that you'll need to use Paste Special in applications which default to paste as text (such as MS Word), because one of the formats copied is text (which consists of the node names).
