Error in SMILE while learning a network with Noisy-MAX node
EAly
Post by EAly »
I'm trying to learn the parameters of the attached network form the data in the attached file. The nodes are three chance parent nodes and one Noisy_MAX child node. However when I run the code, I get this error:
SMILEException: SMILE Error Occured in: EM.Learn
ErrNo=-51
I tried to do the learning using GeNIe and also get an error, but this time it says:
EM: noisy-max nodes are not supported in DBNs
Would you please help me solve this issue?
Noir_data.csv
(30.78 KiB) Downloaded 1485 times
NoirNet_new.xdsl
(2.38 KiB) Downloaded 1418 times
Re: Error in SMILE while learning a network with Noisy-MAX node
Thanks for reporting this issue. It is a bug for which we're assigning a high priority. I'll post here once a fix is available.
We have fixed the issue you have reported. If you want to access a prerelease version of SMILE, let me know what operating system/programming language you're using.
EAly
Post by EAly »
Hi Shooltz,
Thanks for your reply.
Sure, I would like to access the prerelease version. I'm using pysmile on windows 10 64bit.
Thanks again for your help.
Please check your private message inbox on this forum. I've sent you a link to a prerelease GeNIe and PySMILE.
EAly
Post by EAly »
Thanks for sharing this, appreciate your help.
