Enable diagnosis for nodes using pysmile wrapper
hemasadhasivam
Post by hemasadhasivam »
Hello
I am using PySmile wrapper to generate a network.
1. I want to enable diagnosis for the created nodes through code.
I checked the various methods and found the below snippet relevant to what I am looking for.
net = PySmile.Network()
net.set_node_diag_type(handle, int)
But the input arguments accepted by the "set_node_diag_type" method are not very clear and I couldn't find information related to the diagnostic role of a node in the documentation. What does the second 'int' parameter indicate?
It would be very helpful if you could provide some information.
Additional note: I want some of the nodes in my network to be of target type and the others to be observation type and that is the reason why I am looking to use the set_node_diag_type method.
2. Is it possible to change the font type or size through PySmile wrapper?
3. Are there methods to convert the graph to a bar view or an icon view?
Thanks & Regards,
Hema S
Re: Enable diagnosis for nodes using pysmile wrapper
Unfortunately, this functionality is not available from PySMILE.
We will write a sample Python program using PySMILE's diagnostic functionality and post it here.
Post by piotr [BayesFusion] »
First argument of set_node_diag_type method is node handle or node ID. Second argument represents diagnostic type. By default, all nodes are Auxiliary.
You can change diagnostic type by calling e.g.
net.set_node_diag_type("Fault Node ID", pysmile.NodeDiagType.FAULT)
net.set_node_diag_type("First Observation Node", pysmile.NodeDiagType.OBSERVATION)
net.set_node_diag_type("Second Observation Node", pysmile.NodeDiagType.OBSERVATION)
Besides of that, at least one state of fault node must be marked as "fault outcome".
net.set_fault_outcome("Fault Node ID", "Fault Outcome", True)
Ranked observations could be setted with method net.set_ranked:
net.set_ranked("First Observation Node", True)
Then, you can run diagnosis with creating DiagNetwork object and running update method.
diag_net = pysmile.DiagNetwork(net)
diag_result = diag_net.update()
hemasadhasivam
Thank you for the update. It's very helpful.
katelynmorrison
Post by katelynmorrison »
Hello, I am trying to get the diagnostic values from my model using the pysmile wrapper. But currently, I am struggling on figuring out how to do this.
Based on the answers below, I have generated this code so far:
net = pysmile.Network()
net.read_file("Survival.xdsl")
for i in range(len(current_features)):
    net.set_evidence(current_features[i], mapped_values[current_features[i]])
net.update_beliefs()
beliefs = net.get_node_value("SURVIVAL_12")
# Iterate through the outcomes
for i in range(0, len(beliefs)):
     outcome = net.get_outcome_id("SURVIVAL_12", i)
     probability = beliefs[i]
     print(f"{outcome} = {probability}")
net.set_node_diag_type("SURVIVAL_12", pysmile.NodeDiagType.FAULT)
net.set_fault_outcome("SURVIVAL_12", "Yes", True)
     net.set_node_diag_type(current_features[i], pysmile.NodeDiagType.OBSERVATION)
diagnostic_values = diag_result.get_node_value("SURVIVAL_12")
for i, outcome in enumerate(diag_net.get_outcome_ids("SURVIVAL_12")):
     value = diagnostic_values[i]
     print(f"{outcome}: {value}")
Running this code, I get the following output:
No = 0.0028522731146181338
Yes = 0.9971477268853817
Traceback (most recent call last):
  File "pysmiletest.py", line 151, in <module>
    test()
  File "pysmiletest.py", line 144, in test
AttributeError: 'pysmile.DiagResults' object has no attribute 'get_node_value'
Any suggestions on how I can access the diag_result and/or if I am doing something wrong in the code here?
The current features in the model I have include several health-related variables such as heart rate, gender, age, blood pressure, etc., and these variables all predict Survival.
Any insight and help would be appreciated!
When you operate on the DiagNetwork object, you should use the instantiate_observation method, instead of set_evidence. After creating a DiagNetwork object based on Network, add a loop similar to the one you pasted at the beginning of the code snippet (changing net.set_evidence to diag_net.instantiate_observation)
    diag_net.instantiate_observation(current_features[i], mapped_values[current_features[i]])
The DiagResults object consists of two lists - observations (list of objects of type ObservationInfo) and faults (list of objects of type FaultInfo). You can refer to them as follows:
diag_result.faults
diag_result.observations
You can get more information about these objects using the help command in the Python interpreter e.g.
help(pysmile.DiagResults)
help(pysmile.ObservationInfo)
help(pysmile.FaultInfo)
