Does a GPU helps?
rmorales
Does a GPU helps?
Post by rmorales »
We are creating a web application for modelling competence development by students, and we are in the process of creating dynamic bayesian networks on the basis of a competence map with around a hundred nodes (about 1.5 parents per node). We are requeting support from Amazon Web Services to host the server, and they have asked me if I need GPUs. So the question: is SMILE (pySMILE) able to take advantage of GPUs?
Regards,
Rafael
Re: Does a GPU helps?
SMILE does not use the GPU for speeding the calculations.
We're using SMILE on AWS for a couple of years now, including AWS Lambda (serverless). We didn't encounter any problems, but if you have any AWS-specific issues, let us know.
