stopping rule for sampling methods
Maral Arastoo
Post by Maral Arastoo »
I would be grateful if you could help me with some questions.
I have built a massive network in GeNie. The network is too complex to be handled by exact inference methods so I am using sampling methods to perform inference. My problem is that I do not know how many samples are enough to get a good answer. Is there any stopping-rules implemented in GeNie?
Also, I have read in the manual that GeNie calculates the amount of memory needed for inference and if there is not enough memory it returns "Error(-42)". Is there any way for the user to find out how much memory is needed (even approximately)?
Best regards,
Maral Arastoo
Re: stopping rule for sampling methods
Regarding error -42, currently there's no way to obtain an estimate on memory required - it's likely to be very large anyway.
Before switching to sampling algorithm, try setting explicit target nodes in your network. This may reduce the complexity for inference algorithm.
If you're still getting error -42, even with targets, switch to EPIS inference. To set the number of samples, use Network Properties|Sampling page. The running time is roughly proportional to the number of samples.
Maral Arastoo
Thank you for your prompt reply.
I have set the target nodes but it still does not work.
But how can I asses the performance of the sampling methods? How many samples are needed given an accepted error? Are there any stopping rules implemented in GeNIE?
Thank you.
The 'stopping rule' is just a number of samples which you can set in Network properties|Sampling.
