The user guide says that at the Discretization tab of an equation node, if I select Elicitate, I can manually edit the CPT. But I just cannot do it. All the numbers in the CPT table are not editable. Why?
Charles
A simple question
Re: A simple question
The Elicitate command opens the interactive chart where you can move the interval boundaries with a mouse. The CPT is then adjusted accordingly. Note that GeNIe does not store the discretized CPTs in the xdsl files - only the intervals. The CPTs are derived at runtime.
We'll fix the GeNIe manual to avoid the confusion - currently the information about the Elicitate command is incorrect.
Thank you. Got it.
Charlie
Charlie
