Dear administrator
I have a network with equation nodes and got the following message (excerpted) in the Output window:
Discretization problem in node NumLights: Overflow samples: 156, max=124.02 hiBound=100 Total valid samples: 9844 of 10000
Discretization problem in node Best_ESC_price: Underflow samples: 250149, min=5.00009 loBound=15 Total valid samples: 2749851 of 3000000 CPT configs with no valid samples: 20 of 300
What does it mean by "underflow" and "overflow"?
Charles
Re: Discretization problem
During the discretization process the CPTs for the equation nodes are derived by sampling. Some of these samples may fall outside of the bounds specified for the node. If the sample value is less than a lower node bound, it's rejected and a count of underflow samples is increased. If the sample value is greater than an upper bound, it's also rejectd and a count of overflow samples is increased. After discretization is complete and under/overflow counts are nonzero, GeNIe displays the appropriate message in its output pane to notify an user about possible problem with the variable domain specified by the bounds.
In your case, NumLights variable has an upper bound of 100, but there were 156 samples with values larger than 100, the highest being 124.02. For Best_ESC_price there were 250149 samples with values less than 15.
Generally, this kind of message is a warning, not an error.
Thank you for the explanation.
Charlie
Charlie
