Genie installation error code 500 in ubuntu 16.04
I am trying to install genie in ubuntu 16.04, I have installed wine and then installed genie as well, but at activation time with a free trial of 30 days the error code 500 shows every time. how to resolve?
Re: Genie installation error code 500 in ubuntu 16.04
It is hard to say what exactly is happening in your environment but here is the address of the page with Microsoft error codes:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
It seems that your error (500) is:
ERROR_USER_PROFILE_LOAD
500 (0x1F4)
User profile cannot be loaded.
Could it be something in your Wine installation?
I hope this helps.
500 (0x1F4)
I hope this helps.
Marijn Peppelman
Hello.
I've had this problem as well on ubuntu 14.04, and managed to solve it, so i wated to document the solution here for future use.
First, check if your wine installation is up to date.
The 14.04 repo (which i used) was on versopn 1.6.2, but wine is well past version 4.0
In order to get a more up to date version, I needed to add the WineHQ repository in order to get the latest version, see HERE.
Next, I ran "winecfg" in the terminal, which downloaded some extra modules for wine which don't get installed with the usual 'apt-get install wine'.
Among these modules was a module handling http stuff, and given that http 500 is the "internal server error" code, this might have been the cause.
Afterwards, everything ran fine using "wine <path to genie.exe>", and I was able to register successfully.
