Hi Goodday,
I use data1 to train my Bayesian network which created by Genie. Then, it will gv me a new set of Learned Network. With the new learned network,i m using data2, i set the S and M as evidence and i would like to obverse HB. But it seem doesnt work out..
Error show in smile as below:
Exception in thread "main" smile.SMILEException: SMILE error -2 in function SetEvidence
at smile.Network.setEvidence(Native Method)
at PaperOne.main(PaperOne.java:43)
Kindly assists. Thanks so much
Bayesian Network doesnt learn
BayesianNetworkNewbie
Re: Bayesian Network doesnt learn
Error -2 may be caused by conflicting evidence from the data file. You can try entering the same evidence in GeNIe (assuming that you can identify which row from your data file triggers the exception).
