- Example.csv
- (1.79 KiB) Downloaded 1297 times
Issues with opening the csv file in GeNIe
Re: Issues with opening the csv file in GeNIe
You need to remove the first line of the file (which is empty, as GeNIe notifies you in the error message). Also, you'll need to set the names of the first two columns in the header line (which starts with two commas).
Thank you very much!
I have one more question if you could answer me. I want to build a Bayesian Network from this data. To do this, the first column and the first line are important? These are the titles of the nodes I guess..
The first line should contain names of the columns. These names will be used to name the nodes in your network if you decide to learn the network structure from the file.
The data in the first column is not special in any way from GeNIe's point of view.
