Hi
Suppose there are three nodes, A, B, c
A->c B->c that is, A and B are the parent nodes of the c-node.
We know that P (A), P (B), P (c | A), P (c | B),How do I get the conditional probability table for c when I set up a Bayesian network in GeNie?
If the parent node is too much, CPT also need to enter one by one?
How do I get a conditional probability table?
Re: How do I get a conditional probability table?
I'm afraid no Bayesian network software will allow you to do that -- you have a theoretical problem. You need P(C|AB) and have only P(C|A) and P(C|B). Without special assumptions about the interaction, you are facing an under-constrained problem.
Please look at the canonical models (Section "Components of GeNIe models" and then "Canonical models"). Even there, though, you need to have P(C|A~B) and P(C|~AB).
