I've leaned network structure with 2100 variables using gtt. When I update the network there is some errors:
Error (-42): UpdateBeliefs failed - network structure is too complex.
Could you please help sovle this?
many thanks
snowave
Error message when update net beliefs
Re: Error message when update net beliefs
If you're only interested in the posteriors for the subset of nodes, mark them as targets. This may reduce the complexity and enable the UpdateBeliefs to complete successfully with the exact algorithm. Otherwise you can use one of the sampling algorithms.Error (-42): UpdateBeliefs failed - network structure is too complex.
64-bit computer running 64-bit SMILE with plenty of RAM may also help.
many thanks it works.
