Error message opening .xdsl file
TimoSamuel
Hi there,
While trying to open a GeNIe file, I got the following message
"Error at 1, 4 while loading C:\Users\Eigenaar\Dropbox\Compleet\GeNIe Netwerken\23-01-2017 PriorModel.xdsl: not well-formed (invalid token)"
I was wondering whether you have experience with this and what I could do to fix/debug it so it becomes operational again?
Looking forward to your reply.
Regards
Timo
p.s. I did save it in dropbox, perhaps there occured a conversion in this process? I have tried to add it as an attachment to this thread but that was unsuccesful as well.
Regards
Timo
Re: Error message opening .xdsl file
We won't be able to help you without the file. The error message contains the row and the column where the problem starts.
TimoSamuel
Ok that makes sense actually, perhaps I can send it to you by email? If you would like to take a look would be great.
Regards,
Timo
Regards,
Timo
You can paste first lines straight into the message (if, as you have mentioned at the start of this topic, you can't attach it).
TimoSamuel
Using Terminal on mac I get this. Does not look too good I'm afraid.. Do you think it is due to UNIX instead of NT? Perhaps the email/wetransfer is a better option?
head -30 PriorModel.xdsl
bookmark88Xrs/T2wYb?6?Aopbo<Users
TimoBreureDropbox
GeNIe Files23-01-2017 PriorModel.xdsl 4D ??CHevR????A?/?? file:///
Macintosh H(A???x$95F7A4F2-1AEE-3AB8-9F13-5608C4CEA545???/4dnibxdsl????????|?@T<U<V4 ? d t ? ? ? ?0 4?H? ?X?4??X"?Brams-MacBook-Pro:Compleet TimoBreure$
Brams-MacBook-Pro:Compleet TimoBreure$ more -20 PriorModel.xdsl
"PriorModel.xdsl" may be a binary file. See it anyway?
book^@^@^@^@mark^@^@^@^@8^@^@^@8^@^@^@X^C^@^@^@^@^D^P^@^@^@^@rs/T2wYb<E5>6<BE>A
^@^@^@^@opbo<^B^@^@^D^@^@^@^C^C^@^@^@^D^@^@^E^@^@^@^A^A^@^@Users^@^@^@
^@^@^@^A^A^@^@TimoBreure^@^@^G^@^@^@^A^A^@^@Dropbox^@^K^@^@^@^A^A^@^@GeNIe Files^@^Z^@^@^@^A^A^@^@23-01-2017 PriorModel.xdsl^@^@^T^@^@^@^A^F^@^@^P^@^@^@ ^@^@^@4^@^@^@D^@^@^@X^@^@^@^H^@^@^@^D^C^@^@ (^F^@^@^@^@^@^H^@^@^@^D^C^@^@<C6>?^P^@^@^@
^@^@^H^@^@^@^D^C^@^@<84>C$^@^@^@^@^@^H^@^@^@^D^C^@^@^\HG^@^@^@^@^@^H^@^@^@^D^C^@^@evR^@^@^@^@^@^T^@^@^@^A^F^@^@<98>^@^@^@<A8>^@^@^@<B8>^@^@^@<C8>^@^@^@<D8>^@^@
^@^H^@^@^@^@^D^@^@A<BE>/<CB><D9>^@^@^@^X^@^@^@^A^B^@^@^A^@^@^@^@^@^@^@^_^B^@^@^@^@^@^@^_^B^@^@^@^@^@^@^@^@^@^@^A^E^@^@^D^@^@^@^C^C^@^@^A^@^@^@^H^@^@^@^D^C^@^@^C^@^@^@^@^@^@^@^D^@^@^@^C^C^@^@<F7>^A^@^@^H^@^@^@^A ^@^@file:///^L^@^@^@^A^A^@^@Macintosh H^@^@^@^D^C^@^@^@^@^@(t^@^@^@^H^@^@^@^@^D^@^@A<BB><AA><E1>x^@^@
^@$^@^@^@^A^A^@^@95F7A4F2-1AEE-3AB8-9F13-5608C4CEA545^X^@^@^@^A^B^@^@<81>^@^@^@
^A^@^@^@<EF>^S^@^@^A^@^@^@<EF>^S^@^@^A^@^@^@^A^@^@^@^A^A^@^@/^@^@^@4^@^@^@^A^B^@^@dnib^@^@^@^@^A^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^D^@^@^@^@^@^@^@xdsl????^@^@^@^@^@^@^@^@^T^A^@^@<FE><FF><FF><FF>^A^@^@^@^@^@^@^@^V^@^@^@^D^P^@^@|^@^@^@^@
TimoBreureDropbox
It's not an XDSL file. This is not a problem related to OS encoding.
TimoSamuel
Ok, that is good to hear then. Do you think I can perhaps have bugged by manually changing the file's name instead of using the save as command within GeNIe's GUI?
I believe the stuff you've printed in the terminal is macOS Finder's alias; it has the "bookmark88" magic header.
TimoSamuel
Ah so that means that the file is an alias making GeNIe reading an error?
That is most likely explanation. XDSL format is xml, the file you have isn't.
TimoSamuel
Ok, many thanks for your help. Guess I would have start a search for the original again then..
