Linux 32 bit versions?
kwistjhp
Post by kwistjhp »
it appears to me that the 32 bit Linux versions on https://download.bayesfusion.com/files. ... y=Academia are actually 64 bit. When downloading and extracting one of the .o files from the archive, file sfo.o returns "sfo.o: ELF 64-bit LSB relocateable, X86-64, version 1 (SYSV), not stripped". The same holds for all three Linux versions. Could you upload the correct 32 bit versions?
Johan
Re: Linux 32 bit versions?
Our downloadable files are OK wrt to 32 vs 64 bit architecture. Here's what I'm getting when running the file command on sfo.o:
smile_linux_x86_gcc_3_4_6.tar.gz
sfo.o: ELF 32-bit LSB  relocatable, Intel 80386, version 1 (SYSV), not stripped
smile_linux_x86_gcc_4_4_5.tar.gz
smile_linux_x64_gcc_4_4_5.tar.gz
sfo.o: ELF 64-bit LSB  relocatable, x86-64, version 1 (SYSV), not stripped
What's the size of your sfo.o file?
kwistjhp
Post by kwistjhp »
Err.. apparently I forgot to copy the correct .a file to the library directory my makefile was referring to... Sorry for the inconvenience :$
