Marginalisation Noisy Adder
joergweber79
Post by joergweber79 »
suppose to have two connected chance nodes A and B (each with only two variables). Then the probability of node B can be obtained by applying:
P(B)=P(B|A)*P(A)+P(B|not(A))*P(not(A)
But what if chance node B is a Noisy Adder with a LEAK of 0.95. How can the probability of B be computed? (see attached file)
1. Can you please provide some Formula?
2. What is the formula for computing probabilities of A and B, after having entered soft-evidence p=0.1 on node B?
Sincerely,
Joerg
NoisyAdder_Marginalisation.xdsl
(1.8 KiB) Downloaded 1266 times
adam
Contact:
Post by adam »
Joerg,
You can read more about the noisy-adder in a technical report and my Ph.D. thesis. These are available at:
http://zagorecki.com/web_documents/zago ... verage.pdf
http://zagorecki.com/web_documents/Zagorecki-PhD.pdf (pages 104-114)
What is known in GeNIe as the noisy-adder in the two documents will be refered as the noisy-average. Sorry for this mess.
There is one more difference -- GeNIe has implemented weighting schema that is not discussed in great detail in those documents.
To achieve the effect of non-weighted model discussed in those documents in GeNIe you should use the weight for leak as a very small value (e.g. 0.000000001) and 1 for all other parents I attached here a GeNIe model that implements the example discussed in those documents.
If you want to see a complete CPT defined by the model it is enough to press the Show CPT button in the GeNIe's node definition dialog.
Adam
(3.25 KiB) Downloaded 1270 times
