Actually, I have two states in each node in a BN.How do I match 10 rows of data for state 1 and 9 rows of data for state 2 of same node.Currently, I can match node with a column of data but I cannot match each state of a node with a set of data.When I do drag and drop, it just one state only matches with one data of the same column.
I am modeling data with BN.Please help me urgently.Thakning you in advance.
Learn parameter
Re: Learn parameter
You can drag and drop the outcomes onto column values and vice versa once the node is matched with column value. In the attached screenshot it's possible to move blue items on the red ones; for example 'Corner' may be matched with 'average'.
- matchdata.png (47.16 KiB) Viewed 5292 times
