Learn parameter
afia
Learn parameter
Post by afia »
Hi! I have a question regarding learning parameters using Genie.I went through Tutorial 16 where it says how can each node learn parameters from a set of data of txt file which is done by mapping nodes with dataset.
My QUESTION is " is there any way to define the mapping the states of node to data set".
It would be really great if anyone could help me.Thanking you.
Re: Learn parameter
afia wrote:My QUESTION is " is there any way to define the mapping the states of node to data set".
Yes - you can simply drag and drop the node states onto column values or vice versa.
