User Properties
User Properties
How does one set user properties in a node?
Re: User Properties
DSL_node *node = net.GetNode(nodeHandle);
DSL_userProperties &props = node->Info().UserProperties();
// add new property
props.AddProperty("MyPropName", "abc");
// change existing property
int propIndex = props.FindProperty("MyPropName");
if (propIndex >= 0)
props.ChangePropertyValue(propIndex, "Modified property value");
else
// not found
Re: User Properties
Thanks!!
(Could I have figured this out by searching the ".h" files?)
Re: User Properties
Probably, as long as you know the DSL_userProperties is the name of the class storing these properties.Could I have figured this out by searching the ".h" files?
