I was wondering if it is possible to access cases created using Case Manager (that hidden feature that you can access using a secret key combination) using JSMILE?
If not, is there any other mechanism that allows to save evidence set in the model and later retrieve it from JSMILE? I'm not doing learning, so if it is possible to avoid data set it would be great...
Adam
Accessing cases from JSMILE
Re: Accessing cases from JSMILE
The case support is at this point available only in C++ SMILE.
BTW, the Case Manager pane in GeNIe is not a hidden feature - GeNIe has a command in the View menu, along with shortcut key (Ctrl+Alt+C).
giliandrea92
I was wondering if the support for cases in jSmile has been added to date.
Andrea
Andrea
Sorry, this feature is not available yet.
