I encountered some troubles when I tried to extract the conditional probability.
1) I got a linear 4-node structure, where B is conditional on A, C is conditional on B, and D is conditional on C. However, when I checked the conditional probability matrix for node, there are 4 elements (there are supposed to be 2 for A). I do not know why.
2) I wonder if there is a way to figure out what each conditional probability represents (namely, the label for each CP), for I noticed the order (or index) of the conditional probabilities has been changing.
Many thanks in advance.
Bo
More questions about Conditional Probabilities in Parameter Learning
Re: More questions about Conditional Probabilities in Parameter Learning
Can you post your network here? The board software accepts attachments. Alternatively, you can copy the contents of your xdsl file into the message.I got a linear 4-node structure, where B is conditional on A, C is conditional on B, and D is conditional on C. However, when I checked the conditional probability matrix for node, there are 4 elements (there are supposed to be 2 for A). I do not know why.
Changing between EM runs?I wonder if there is a way to figure out what each conditional probability represents (namely, the label for each CP), for I noticed the order (or index) of the conditional probabilities has been changing.
Yes, the order of conditional probabilities is changing between EM runs. Because I do not get the rule by which these probabilities are presented in the outcome, it's hard to tell which is which.
Here is the code I used to create the network. There are 30 observed variables, x1.............x30, which are intended to measure 4 latent variables, A, B, C, D. Four latent nodes are linked through a linear hierarchy, A---->B---->C----->D.
Bo
Bo
void CreateNetwork(void) {
DSL_network LIN_4T;
int x1 = LIN_4T.AddNode(DSL_CPT, "x1");
int x2 = LIN_4T.AddNode(DSL_CPT, "x2");
int x3 = LIN_4T.AddNode(DSL_CPT, "x3");
int x4 = LIN_4T.AddNode(DSL_CPT, "x4");
int x5 = LIN_4T.AddNode(DSL_CPT, "x5");
int x6 = LIN_4T.AddNode(DSL_CPT, "x6");
int x7 = LIN_4T.AddNode(DSL_CPT, "x7");
int x8 = LIN_4T.AddNode(DSL_CPT, "x8");
int x9 = LIN_4T.AddNode(DSL_CPT, "x9");
int x10 = LIN_4T.AddNode(DSL_CPT, "x10");
int x11 = LIN_4T.AddNode(DSL_CPT, "x11");
int x12 = LIN_4T.AddNode(DSL_CPT, "x12");
int x13 = LIN_4T.AddNode(DSL_CPT, "x13");
int x14 = LIN_4T.AddNode(DSL_CPT, "x14");
int x15 = LIN_4T.AddNode(DSL_CPT, "x15");
int x16 = LIN_4T.AddNode(DSL_CPT, "x16");
int x17 = LIN_4T.AddNode(DSL_CPT, "x17");
int x18 = LIN_4T.AddNode(DSL_CPT, "x18");
int x19 = LIN_4T.AddNode(DSL_CPT, "x19");
int x20 = LIN_4T.AddNode(DSL_CPT, "x20");
int x21 = LIN_4T.AddNode(DSL_CPT, "x21");
int x22 = LIN_4T.AddNode(DSL_CPT, "x22");
int x23 = LIN_4T.AddNode(DSL_CPT, "x23");
int x24 = LIN_4T.AddNode(DSL_CPT, "x24");
int x25 = LIN_4T.AddNode(DSL_CPT, "x25");
int x26 = LIN_4T.AddNode(DSL_CPT, "x26");
int x27 = LIN_4T.AddNode(DSL_CPT, "x27");
int x28 = LIN_4T.AddNode(DSL_CPT, "x28");
int x29 = LIN_4T.AddNode(DSL_CPT, "x29");
int x30 = LIN_4T.AddNode(DSL_CPT, "x30");
int A = LIN_4T.AddNode(DSL_CPT, "A");
int B = LIN_4T.AddNode(DSL_CPT, "B");
int C = LIN_4T.AddNode(DSL_CPT, "C");
int D = LIN_4T.AddNode(DSL_CPT, "D");
LIN_4T.AddArc(A, x1);
LIN_4T.AddArc(B, x2);
LIN_4T.AddArc(C, x3);
LIN_4T.AddArc(D, x4);
LIN_4T.AddArc(A, x5);
LIN_4T.AddArc(B, x5);
LIN_4T.AddArc(A, x6);
LIN_4T.AddArc(C, x6);
LIN_4T.AddArc(A, x7);
LIN_4T.AddArc(D, x7);
LIN_4T.AddArc(B, x8);
LIN_4T.AddArc(C, x8);
LIN_4T.AddArc(B, x9);
LIN_4T.AddArc(D, x9);
LIN_4T.AddArc(C, x10);
LIN_4T.AddArc(D, x10);
LIN_4T.AddArc(A, x11);
LIN_4T.AddArc(B, x12);
LIN_4T.AddArc(C, x13);
LIN_4T.AddArc(D, x14);
LIN_4T.AddArc(A, x15);
LIN_4T.AddArc(B, x15);
LIN_4T.AddArc(A, x16);
LIN_4T.AddArc(C, x16);
LIN_4T.AddArc(A, x17);
LIN_4T.AddArc(D, x17);
LIN_4T.AddArc(B, x18);
LIN_4T.AddArc(C, x18);
LIN_4T.AddArc(B, x19);
LIN_4T.AddArc(D, x19);
LIN_4T.AddArc(C, x20);
LIN_4T.AddArc(D, x20);
LIN_4T.AddArc(A, x21);
LIN_4T.AddArc(B, x22);
LIN_4T.AddArc(C, x23);
LIN_4T.AddArc(D, x24);
LIN_4T.AddArc(A, x25);
LIN_4T.AddArc(B, x25);
LIN_4T.AddArc(A, x26);
LIN_4T.AddArc(C, x26);
LIN_4T.AddArc(A, x27);
LIN_4T.AddArc(D, x27);
LIN_4T.AddArc(B, x28);
LIN_4T.AddArc(C, x28);
LIN_4T.AddArc(B, x29);
LIN_4T.AddArc(D, x29);
LIN_4T.AddArc(C, x30);
LIN_4T.AddArc(D, x30);
LIN_4T.AddArc(B, A);
LIN_4T.AddArc(C, B);
LIN_4T.AddArc(D, C);
LIN_4T.WriteFile("LIN_4T.xdsl");
Your code creates the hierarchy in the reverse direction; D->C->B->A. Here's the line which connects the parent B with child A.Four latent nodes are linked through a linear hierarchy, A---->B---->C----->D.
