Issues with Extracting Conditional Probabilities
Bo Hu
Post by Bo Hu »
In my network, Node B is set to be dependent on Node A. Both nodes have two states "1" and "0". I use following codes to extract the results of the parameter learning. I want to get all probabilities from the conditional probabilities with respect to Node B: P(B=1|A=1), P(B=0|A=1), P(B=1|A=0) P(B=0|A=0). There seems some problems with my codes because I got the same values for all last three probabilies(P_B_0_A_1=P_B_1_A_0=P_B_0_A_0). This does not make any sense to me. Anything wrong with my codes?
Thanks in advance!
Bo
int B = LIN_4T.FindNode("B");
theCoordinates.LinkTo(*LIN_4T.GetNode(B)->Value());
theCoordinates.GoFirst();
double P_B_1_A_1 = theCoordinates.UncheckedValue();
theCoordinates.Next();
double P_B_0_A_1 = theCoordinates.UncheckedValue();
double P_B_1_A_0 = theCoordinates.UncheckedValue();
double P_B_0_A_0 = theCoordinates.UncheckedValue();
Re: Issues with Extracting Conditional Probabilities
Your code accesses the posterior probabilities, not the conditionals. Also, I'd suggest using the direct access to DSL_Dmatrix object instead of DSL_sysCoordinates.
const DSL_Dmatrix* mtx = net.GetNode(B)->Definition()->GetMatrix();
// read the content of mtx using linear index or odometer coords, for example:
for (int i = 0; i < mtx->GetSize(); i ++)
  printf("%d %f\n", i, (*mtx)[i]);
